CANBUS reads the speed as exact, the dash just shows a certain percentage higher than what the car knows its doing.
Printable View
Any trick to get this working? I have the Android version. I have connected WiFi connected USB and I can't get oneapp to connect
Sent from my Pixel XL using Tapatalk
the critical thing is you need to make sure both the phone and car are on the same wi-fi. or you use the usb cable.
hence 3 ways to do it:-
1. turn on hot-spot on ur phone, and connect the car to the phone's hotspot. Skoda OneApp will then be connected to your car.
or
2. turn on WLAN on your car, and connect the phone to the car's wifi. Skoda OneApp will then be connected to your car.
or
3. use the USB Cable. Skoda OneApp will then be connected to your car.
With regards to #1 and #2, the Skoda OneApp cannot be shown on the infotainment system.
To do that, you need to connect via the USB cable.
i've tried all 3 ways, and they all work.
Not working with Android or iOS? I've tried methods 2 and 3 without success but I'll try one and retry methods 2 and 3 again as well
i have both android auto and skoda one app on my phone - both have been behaving.
SmartLink will remember the last mode (android auto or mirrorlink), and automatically reconnect.
the annoying thing is with my phone, everytime i connect the usb cable, i gotta change the usb connection type from 'charging' to 'data transfer', otherwise SmarkLink bails on me.
Got it working.... had to shutdown android auto... i found that private road....... 5.0 out of D and 4.5 out of S
Sent from my SM-T800 using Tapatalk
