Page 214 of 222 FirstFirst ... 114164204212213214215216 ... LastLast
Results 2,131 to 2,140 of 2212
  1. #2131
    Aug 2020
    victoria
    Well today I got my 2008 MK5 r32 back.
    Had the timing chain done and the camshaft adjuster done.. $4800 pretty sure I got ripped off.
    $3250 for the timing chain initially... then a phonecall saying the camshaft adjuster exhaust needs to be replaced to. $1400. doing some research part only goes for like 900 AUD. Feel gutted should have done my research first before telling them go ahead. Won't even be able to enjoy the car now seeing as I spent probably 30% of its value.
  2. #2132
    Replaced DMF.
    1.9 TDI DSG with 185000km.
    Shifts are smooth as butter, no chatter in P/N or rattle on shutdown.
    Happy days.
    What did you do to your Mk5 today?-screen-shot-2020-08-24-8-49-19-am-jpg
  3. #2133
    Sep 2016
    Bit quiet in here...No more love for the mk5 it seems!
    I still have mine with 170k on the clock and just did a suspension refresh with adjustable tein coilovers, new sway bar ends and Audi TT lower arm bushes. Seems a bit tighter now What did you do to your Mk5 today?
    Sent from my SM-G977B using Tapatalk
  4. #2134
    Jul 2007
    Brissy
    I replaced engine and trans mounts today. Lately there have been a few thumps from 1st to 2nd at low speed and from park to reverse on a cold start.
    I cannot believe how worn they were. I had to raise the engine about 2cm get the new mounts close enough to bolt down.
    What did you do to your Mk5 today?-trans-gap-jpg
    There should be no gap here !
    What did you do to your Mk5 today?-trans-slop-jpg
    Trans old vs new.
    Similar story on the engine mount.
    What did you do to your Mk5 today?-engine-slop-jpg
    Engine old vs new
    Time will tell if it fixes the hard shifting.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  5. #2135
    Jul 2007
    Brissy
    Did another door lock today. Bought back in July, finally had enough of the intermittent failing to unlock, always worked when using internal handle however.
    That is 3 now, just the driver's to go. Do I wait or get in early ??
    MK4 GTI - Sold
  6. #2136
    Quote Originally Posted by JustCruisn View Post
    Trans old vs new.
    Engine old vs new
    I do this about month ago, replacing streching bolts is must for this work.
    I once put back old bolts, and threads go bad when i turn last 90 degrees, engine become lose on this joints and must replace also mounting brackets.
  7. #2137
    Today i was replacing tailgate wire loom on left side, 5 wires touch each other and back lights didnt work properly, i use solder iron and strech tubes, 3 hour work.
  8. #2138
    brisbane
    hi mate
    i have the same hard shifting, do you mind saying where you got the mounts please and if its a hard job to do or not, thanks in advance…
  9. #2139
    Erskineville, NSW
    Quote Originally Posted by Andrejm View Post
    They only stretch once.
    If you choose to re-use you have to treat them like a normal bolt and use some feel. Alternatively, replace with a generic bolt from the fastener shop and make an educated guess on the correct torque.
  10. #2140
    @brad yes,this i learned for additional £40,new bracket.What did you do to your Mk5 today?
    But now i had this revised version of bracket, on this bottom holes can enter processed nut and dont care anymore for over streching.
