ETKA can be used for finding part numbers, you pay a small fee and then you can download pages for a period of time. Personally never used it, but plenty of people on here have.
In this case i simply Googled, I find with the VW/Audi's that you can normally find a part number pretty quickly on either a US or UK site and then Google the part number directly to find who is selling it.
2017 Ford Fiesta ST
I have the same problem.
Has the o-ring replaced the problem?
Thanks Lucas for the links to the singe o ring, I could only find the link to the set of o rings.
I did an oil change not long ago and found some oil drops on my driveway. I was hoping it was leaking from the sump plug lol.
Sent from my SM-G965F using Tapatalk
MY07 Red GTI 3 Door
Sorry for delayed response mate.
There is an O-ring on the coolant sensor which I didn't replace as doesn't seem to leak. I replaced the gasket that seals the pump and also an internal O-ring was changed. It seems to have fixed the leak but I've noticed there is still some oil residue on the cable underneath... Not sure if that's from before
A replacement vacuum pump is about $400+ from memory so the way I saw it was that it's worth replacing the gasket for $70 as a start
Sent from my SM-G977B using Tapatalk
i think i have the same issue. I just took mine apart tonight and was filled with oil all over the pump and transmission.
i will say that mine also looked like it was coming from where the cam chain is on the FSI and the gasket around there so i am just changing that in case.
I am hoping this will fix my oil leak which was dripping down bottom but i could also have a rear main seal....fingers crossed.
I forgot about this.
I ordered the Single o ring as recommended by Lucas: Vacuum Pump O Ring for Audi A3 A4 Volkswagen Eos Jetta Passat 06D145117 | eBay
Wasn't difficult to change.
$12 is much better than the hundreds for a new vacuum pump.
The replacement o-ring looks slightly thinner than the original one.
The car is still leaking a tiny bit of oil, but I'm assuming it's from the residual oil in the engine bay. I'm confident it fixed the underlying oil leak as the vacuum pump is clean.
I'll wait until the next oil change to fully degrease the engine from underneath.
MY07 Red GTI 3 Door
