Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Speedo Error R32
    Sep 2008
    Melbourne, Australia
    Speedo Error R32
    As I was driving onthe Eastern freeway most of the traffic was passing me??
    I turned on my Navman and my speed was about 94kph.
    My speedo was reading 100kph.
    I sped up until Nav was 100kph, speedo reads 107.
    I checked again with gps in phone and got same error. Has anyone else found this? Did VW fix it for you?
    Bazle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
    Dec 2006
    Kilsyth, VIC
    Check out this post:
    http://www.vwwatercooled.org.au/newf...ad.php?t=10698
    and this one for how to make your climate control show your speed (maybe)
    http://www.vwwatercooled.org.au/newf...ad.php?t=16701
    Dec 2007
    BNE
    i notice that u have a 08 model, if your climate control doesn't have an econ button, press the AC button instead.
    btw all cars have speedo that reads lower than actual speed.
    Jan 2008
    Quote Originally Posted by bazzle View Post
    Volkswagen Speedometer Error Correction
    Sep 2008
    Quote Originally Posted by Nardi330 View Post
    Thanks, I would rather read the speedo. Actuall not all cars have speedos that read low. I am in the Auto business and see new cars quite a lot. We check speedos as part of our development work.
    Cheers Bazzle.
    Logzy Guest
    Quote Originally Posted by Maverick View Post
    Trouble with corecting the speedo in the cluster using vagcom is that you then put the odometer out.
    Feb 2008
    New Zealand
    If your that desperate to get it changed
    Buy Vag Commander 5.1
    Download the eeprom from the Cluster and you can reprogram the needle sweep map i think
    not really sure if thats possible with mkVs any way.. i dont really know much about it.. ive just read things breifly Graeme86 seems to know a bit about it
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Sep 2008
    Reading the links posted here and from other sites this seems to be a common but annoying problem.
    I know I can mentally judge my real speed or drive off the gps but I didnt buy the car to do that. I have always had accurate speedos and it is nice to know when you are doing 100 that is what it is. It is up to me then if I want to slow etc.
    The real annoying part is when Im doing 100 (and by the look of it other VW owners too) and believe Im doing 100 and a line of cars is behind wanting to overtake.
    I will investigate my options with VW.
    Bazzle
    Jan 2008
    Quote Originally Posted by Logzy View Post
    Trouble with correcting the speedo in the cluster using vagcom is that you then put the odometer out.
    No it doesn't, the odometer is always accurate, VW have put an offset on the speedo so that they meet UNECE 39/00 (Rev 1) which requires the speedo to deliberately under-read. The link that I posted has all the information including copies of the Volkswagen TSB's that explain this.
    Jan 2008
    Quote Originally Posted by HitmanR32 View Post
    The eeprom map from the cluster? the needle sweep map? Read the link that I posted that has all the information on how to do this with a VCDS/Vagcom cable in about 5 minutes and also has copies of the VW TSB's on why/how to fix this.
