Results 1 to 8 of 8
Thread: reverse clunk noise on 2.0fsi
    Aug 2009
    Sydney,NSW
    Hi guys,
    when i reverse parking,sometimes i can here a clunk noise from the rear wheels or brakes.not all the time just every now and then.i read something similar here before but can't found any using search. does anyone have this noise before and can help?
    just been to service and been told all brakes are fine.
    thanks
    2013 POLO GTI Black
    2005 MKV 2.0 FSI Black
    Canberra
    Maybe light rust on the disks from parking after rain/washing ? My Octy sometimes gives a good clunk as the pads free up from the disks, and I also get a light "swooshing" noise and a sort of gritty feeling from the first few brake applications as the rust wears off.
    Other possibilities are a worn DMF (manual gearboxes only) or engine/gearbox mounts worn/RS.
    Jan 2010
    I get the same thing (2.0 FSI). No idea what it is though....
    If you have DSG and you're switching from D or P to R you might come across a slight clunking noise especially when the car is on a hill
    MKV GTI Pirelli
    Sep 2009
    Melbourne, VICTORIA
    I'm pretty sure its the physical movement of the whole engine and transmission when you go from D to R. When you change from D to R, you will notice if you take ur foot off and dont accelerate, the car will move in reverse on its own without making the clunking noise. Once it starts moving, then you can accelerate without a problem.
    To fix the issue (or at least reduce it), there are many engine mounts and engine mount inserts you can buy, which reduce the engine movement.
    _
    2006 Golf GTI DSG | REVO Stg2+, REVO Stg 1 DSG, X-FORCE TBE, K&N Typhoon CAI, AT HPFP, Forge Twincooler, BSH Stg2+ Catch Can, ECS Mount Insert, DBA 4000 Slotted Rotors
    Jul 2007
    Blackburn South VIC
    Check the rear pads, they chew them out real quick.
    I've done 2 sets of rear pads, same year.
    Sep 2008
    Melbourne, Australia
    Also the pads do get a bit of end play, as you go one way and stop ang the other they can :click: in the seats of the calipers, pretty normal, fronts may do it too.
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
    Aug 2009
    Sydney,NSW
    Quote Originally Posted by bazzle View Post
    Bazzle
    so do I need to fix it ?an how? Or this is just normal mechanical movements that won't harm the car?
    2013 POLO GTI Black
