Results 1 to 8 of 8
Thread: Oil / grease around front left CV
    Oct 2010
    Anyone got any ideas why its like this and if its a problem?
    Golf GT Sport TDI
    Jun 2011
    Sydney NSW
    Yes, it is a problem.
    Looks like the rubber boot has failed. It might not be obvious at first, but these mouldings are known to end up with pin holes where the mould joins are.
    When it stops spreading grease around, it simply means that all the grease has gone.
    Depending on the age, as things are apart, it might be worth replacing the CV joint as well as most kd what needs to be done for that will have to be done anyway.
    Dec 2008
    Sydney/Canberra
    Looks like the boot is split, which is normal wear and tear.
    From memory, to do the inner one pictured, you may need to disassemble the outer one to get it off.
    I could be wrong, as the MK5 has a couple of different setups.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by wai View Post
    The CV joint is most likely ok. The inner ones don't wear like the outer ones do. Once it's all apart, give it all a really good clean.
    If you buy the genuine kit, you get new grease, a boot, clamps, belleville washers and circlips where applicable. You'll need one kit per CV, and inner and outer are different.
    Also, you can't cheat by cutting the old boot off, and using a boot expander to get the new one on, the genuine boots don't have much flex in them to stretch over the CV.
    '01 Beetle 2.0
    Oct 2010
    Yeah right so the boot actually locks the grease in hey. I'm guessing this is something I should fix fairly quickly so the joint isn't screwed?
    Thanks for the replies.
    Golf GT Sport TDI
    Erskineville, NSW
    take it to a CV joint specialist. They'll clean, relube the joint & replace the boot in a flash & it won't cost much.
    Jun 2011
    Sydney NSW
    Quote Originally Posted by jazd View Post
    You want to get it done as soon as possible. From the picture, the boot does not appear to have a cut in it. If that was the case, then dirt getting in will ruin the joint very quickly.
    You do not want to delay it.
    Mar 2008
    Chatswood, NSW
    I just had the exact same thing on my MKV GTI, i noticed some grease on one of my rims so had a look underneath and noticed both boots had splits in them. I took it to my mechanic who said that if I left it too long the CV's would end up going, so I had the boots replaced fairly quickly, it was a labour intensive job which cost me $400 all up.
    MKV GTI
