Are you still running the stock air intake? Would be good for a few more horses and the carbonio looks superb
How's the full APR Exhaust? I'm looking to buy either a TBE or DP for my Pirelli also but I'm scared of the TBE being a bit too loud even if there are minimal gains over the DP, the last thing I want is going on a 100km highway drive with the exhaust blaring over my music or just even my thoughts!
Forever blowing bubbles.
Hey mate...
haha well if it's the template for the R20T you'd better get your chequebook out for one! This thing has been a labour of love in both the time, and the cash department!!!!
Yep. To be honest I'm really not sure what to expect. I only know it'll be in the 5's somewhere....
I did get a 5.8 using Dynolicious before the exhaust, IC, Fuel Pump and lightweight wheels went on.. So I'd be a bit disappointed if it doesn't break 5.5. It's certainly down to technique though, as you need to get that boost on as early as possible with these cars.
I had it done by a mob called "Pro Auto". The Dyno was great, and the service was fantastic. I don't think they were entirely "euro friendly" though. Lots of mutterings about "Effing Germans" and "Bloody FWDs"....
Very nice setup though and the service was great. I can enquire about a Dyno day if you guys like????
I took some very good advice in the handling department, and decided to leave the KW's as the only change in that area. From my understanding, a certain (although not a great deal) of bodyroll is fine. It gives the tyres their best opportunity to do their job. Frankly, I had this thing going around corners at AHG at the limit for what I could handle and I wasn't left wanting any more grip or firmness in the suspension dept. For all the postering, GTI's aren't really a track car - although they do a pretty good job at it.
You guess right, and well spotted!!!.. I should try and be a bit more consistent I spose!!!....
Mate the APR exhaust is spot on. I'm not kidding when I say unless you're giving it a bootful - you won't really notice much difference. There is certainly NO drone whatsoever at high speeds (anything under 150 anyway). It only comes on song when you really put the foot in. Great setup. Obnoxious as hell when you want it to be, otherwise it's a pussycat.
Yeah I dunno hey. Personally I don't really like the look of them. They look too tacky (but that's just me) - plus I've read a few bad reports about them from place to place... I reckon if I was going to go CAI, I'd probably go with the K&N engine-bay jobbie. I've seen some brilliant looking powdercoated intakes, but nothing that allows you to keep the engine cover on..
To be honest, a few extra KW isn't really worth it when you're already pushing out 220-240. If I was after more horses (which I'm not saying I'm not) then I think I'd probably go with the bad boy garrett turbo from APR. 285 KW (or more depending on what fuel you're using). I just dunno.. As it drives now, and even after all these months of owning it, it still shocks the bejeezus out of me up to 100ks...
I gotta say it's tempting though. I'm already in for serious dosh on this car (you really don't wanna ask) - so an extra $10k to extract the next monster step up in power is certainly attractive...
Maybe I should rub up the APR guys in the right way, it's practically an APR poster child as it is.
Cheers guys.
Another question Kryten, did you end up getting the very lower rear bumper painted black yet?
Krysten, I'm interested to know.. Wouldn't it have a better air flow with an aftermarket air filter? Like gruppeM or sth like that..
Very nice write up and pics to match!
Enjoy the big brake upgrade and the coilovers for track duties! The wheels match it to a T as well!
Did the APR exhaust include the dump pipe?
My car also had trouble on the Dyno with DSG - Both Bazzles and mine have the same same mods (i have a filter) and there was 20KW difference at the wheels!
.:R32 | GIAC | HALDEX II | MILLTEK | BMC | WHITELINE | A-ROTORS | HAWK
The car looks fantastic. I love yellow cars.
Could you explain these 2 statements please?
How would lighter brakes reduce rolling resistance? Do you actually mean unsprung weight?
How does reducing unsprung weight of the brake calipers aid in increasing performance (I assume you mean acceleration)? I can see it would improve the operation of the suspension but I can't see how it would affect acceleration. Reduced weight in the wheels would help acceleration but not brake calipers (or are the new disc rotors lighter?)
brad, I think you'll find that kryten2001 probably meant "unsprung weight" and not "rolling resistance".
Well, as for acceleration, minimal if any since you quite rightly point out, if the weight of the wheels were significantly lighter, the torque or force to have it spun up to a certain rpm would be lessen - hence translating to better acceleration and braking, since the mass is reduced. As for lighter brake calipers leading to better acceleration, ummm, unless they were 40Kg each before and the brembos 5Kg each, there wouldn't be much of any difference I would have thought. It would significantly improve roadholding though - reduced unsprung weight.
2009 .:R32 5Door Black Magic DSG Sunroof Stubby Antenna
2007 Honda CBR1000RR Fireblade Yoshimura RS5 Carbon Fibre Pipe
Firstly great write up and some very nice mods, the way I like it. All functional mods with great taste (i want them wheels LOL)
Your Pirelli gets me a littttttle too excited
The best method I have found for holding a gear is to select D and then push shifter to the left for Manual Mode.
After doing this the car will not shift down unless you floor the accelerator and then press that little bit harder to compress the kick down button under the pedal.
It will still kick down if the revs are out of boost zone though as you all may know :p
Great write up. If I had a Pirelli and the cash, I think I'd do basically the same mods.
I've love to know what she does down the 1/4 mile.
2000 Mk IV GTI
