I would get at least 2 more opinions on it, before doing anything. Has the transmision place you took it to any experience with the VW AT?
If not, just take your car to an independent VW specialist for another opinion.
Hi All
My wife has a 2005 VW Golf 1.6L Comfortline with 6 Speed sports Automatic
It is a great little car however the transmission has started to play up and is terrible in traffic.
It has done 140,000 km and the transmission has started playing up to the point it will not drive reliably for more than 20 minutes or so. When it is cold it is ok, and gets worse to the point that it is shunting into gears both accelerating and slowing down.
We took it to a transmission repairer and they advised that it would cost between $5,000 to $6,000 and said it was quite bad and not just the valve body.
Just wondering if anyone has had there transmission replaced and who they went to ? and how much it cost?
Also if there is any other options to get it repaired, maybe another transmission from earlier or later golf? Either manual or auto?
The other question I have is if we get it repaired, how do we know if the same thing will happen, are they fixing the actual problem or just putting the same transmission back in??
The more I read the more I find that this was a VW problem and in other coutries there were recalls etc
Appreciate any help that you guys might be able to provide, we are not sure what to do as the car is probably worth around $10,000 (if the transmission was working). Maybe we should try to sell with the damaage for $5,000 or something like that?
Any thoughts?
Unfortunately sounds like you an 09G transmission, (gearbox type) and these can be problematic after 80k, seen plenty. 9 times out of 10 just doing the valve body doesnt fix the problem. I do some work for a couple of repairers and have seen the carnage for myself. The tranmission makes metal and in turn damages the valve body, there is bushings that get damaged in the valve body as well. The valve body gets reamed and rebushed as part of the fix but the whole transmission reqs overhaul at the same time or it will happen again prematurely. Seeing it lots in the transporter now too that has the same physical internals (09K) , same deal with it but seen a bit more on the 09K , sometimes K3 clutch hub can sustain damage and this can sometimes be hairline and go un noticed till the trans is rebuilt. Anyway hope that helps a bit, not much positve i know. Shame really as they are very good cars when working right.
Jmac
Alba European
Thanks for the info Jmac
It isn't great news, as you mention they are great cars when all is working..
I am hisitant to spend the money unless I know it will be trouble free, and not happen again for some time.
If I get the transmission fixed do they fix the underlying issue which has caused these problems, or will it just happen again in a few years time?
Could you bolt on a newer VW gearbox to the engine that doesn't have the problem/would this be an option?
i.e something after 2008 that didn't have the recall's in USA etc.
Hoping the guys on the forum in Melbourne can recommend some places if anyone has gone through the same issues here and roughly how much it will cost.
Currently I am stuck with a car that I cant drive and most likely will have trouble selling, and will cost over half its value to repair.
Appreciate any help you guys can provide.
I don't think the place we went to has had a lot of experience with VW Golfs, need to find another place close by.. Hoping the car will be able to get me there without breaking down!
If it was me I would be calling up wreckers and looking for a second box. If you are worried it will happen again the best thing you could do is sell the car once its repaired, as putting in a manual or a newer transmission will just be expensive, painful and not really worth the end result. That gear box was not used again after the MKV so it could always be a good time to upgrade to a base model MKVI.
MKV GTI
Personally i wouldnt get a secon hand one unless you are fuklly sure of its history, could end up as bad as the one you have
Jmac
Alba European
volkswagen uses A+B gearbox reconditioners in melbourne i think thats where there based they give good warranty there not the cheapest but would say there the bestest they should have a box on the shelf give them a call. these guys were the volkswagen recomended repaires they reconditioned all autos and DSG boxes before they started sending them back to germany
