Results 1 to 7 of 7
Thread: Need pinout for DSG shifter connector
    Mar 2016
    Does anyone have the pinout for this plug which goes to the DSG shifter surround? 2007 Mk5
    Sent from my Samsung Smart Fridge
    .:Mk5 R32
    Check your email mate
    Mar 2016
    Thanks for that. What I'm actually trying to determine is where 'L101 - Selector lever display illumination bulb' receives power from and which pin/s on that connector are for power. Having a look over the diagrams I can't seem to trace it back to anything.
    .:Mk5 R32
    Looks like it's at T10v/8 (grey/blue). This just connects the LED in the selector display panel Y6 to the J587 selector control unit underneath it.
    Mar 2016
    So I assume the selector mechanism receives power from the CECM then?
    .:Mk5 R32
    Yes it's powered from the CECM at T10s/6 (under selector lever cover) which is a grey 0.35mm cable that ultimately connects to the CECM at B12 grey 0.75mm (via B340 in main wiring harness)
    Mar 2016
    Excellent thank you! The reason I ask is because the gear indicator lights on the DSG knob surround aren't lighting up anymore and I'm trying to firstly determine how they're powered.
    I'm guessing it's an internal fault however somewhere within the selector mechanism and it's going to have to be replaced to fix it. All my other interior lights work fine and no errors in VCDS, can't see what else it could be.
    .:Mk5 R32
