Results 1 to 10 of 14
Thread: My 60,000km MKV GTI Service Pricing
    May 2009
    Ok, i'm sure quite a few of us are heading towards the 60,000km mark, which is a major service.
    There are 2 major price variance for this service depending on the year and transmission.
    Basically, if you have a manual car, the price of the dealership service is $900 (+/-10%)
    If you have DSG, it goes to $1400 (+/-10%)
    and if you've had your car for 4 years, you'll also need to change the timing belt which will cost a lot more. (also meaning you might as well change the water pump)
    Anyway, I shopped around different Dealerships in Melbourne and found South Yarra being the most expensive while Camberwell being the cheapest..
    However, as I work near South Yarra, they were the most convenient, so I rang them up, told them Camberwell was doing it at a certain price, and they came back and said "yup, we'll do the same..."
    Anyway, ended up getting the 60,000km service and the DSG service for $1130 all inclusive. Still pretty expensive, but you pay for the convenience i guess.
    Sep 2007
    Rowville, Victoria
    Quote Originally Posted by multi97 View Post
    Hmm,
    sounds very expensive compared to my 60k service in Feb this year. $572.55 @ Barloworld Glen Waverley. I must add this price is probably influenced my my leasing company who use them as a preferred supplier.
    Cheers,
    Neil
    BeigeJet
    White MY23 Tiguan 147 TDI Elegance (mine)
    White MY21 Tiguan 147 TDI Elegance (wife)
    Gone - Wheat Beige MY07 Jetta TDI manual
    Jan 2008
    Quote Originally Posted by BeigeJet View Post
    Hmm,
    Cheers,
    Neil
    You don't have a DSG gearbox. ~$500 of his service was the DSG. $1130 - $500 = $630 which is under $60 difference.
    DSG services should be between $400 and $500 normally.
    I think the manuals require a fluid change at some point don't they but I assume that would be only a few hundred dollars?
    Sep 2007
    Rowville, Victoria
    Quote Originally Posted by Maverick View Post
    So what makes the service of a DSG that expensive? Forgive me for asking but I may as well understnd now that Jetta's don't come with a manual in the 2.0 TDI guise.
    When the lease is up on my TDI my choices are now a little limited
    BeigeJet
    Sep 2007
    Rowville, Victoria
    Not sure when the manual tranny has a fluid change. The handbook is not real specific and it has not changed yet.
    A 90k service is coming up in about 2-3 months so will report back if it is changed then.
    Cheers again!
    BeigeJet
    Jan 2008
    It's mainly because it's a slightly complex operation because of the gearbox design, the clutches and even the controller are immersed in an oil.
    Volkswagen DSG Mechatronic Replacement
    I have a list of parts on the link above but there is 6 litres of DSG oil for ~$160, a transmission filter for ~$65, a few seals for ~$5, disposal of the old oil and 2-3 hours of labour ($200-$300). There is a special tool required to fill (you can make your own) and you have to connect the car to a dealer tool or vagcom/vcds and run through the gears with the engine running to refill the box.
    The price is pretty reasonable when you consider the boxes complexity and the cost of the not maintaining it!
    Dec 2009
    Melbourne, AUS
    only got 45K on my Mk5 GTi atm so there is a while until I do a major service but I did manage to get a 3 year extended new car warranty with Camberwell VW
    MY07 VW Golf GTi
    Eurospeed
    GIAC 2.0T ECU tune
    GIAC DSG program
    Nov 2006
    Clayton South, Victoria
    I'm getting conflicting advice about changing the timing belt. Some people are saying it needs to be replaced at 60,000 / 4 years but the Volkswagen service schedule says it should be replaced at 120,000. The only thing that I can see for the 60,000 / 4 year service is new plugs and new air cleaner element.
    Dec 2008
    Lilydale, Victoria
    Timing belts for these petrol engines (extract from official VW document solely on timing belts)
    document date July 2005.
    2.0L AXW / BLR / BLX / BLY / AXX / BWA / BPY
    From launch, no first check, no subsequent check, change interval 120,000 miles.
    That's 180,000 Kms.
    Jan 2008
    Quote Originally Posted by macdoc View Post
    That's 180,000 Kms.
    That's 2005 and the time the Mark V was first manufactured. Volkswagen update their recommendations based on how items perform and changes to materials used in the production process hence the new requirements.
