Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: MK5 TDI rough start issue
    Dec 2014
    St Clair, NSW
    Hi Guys,
    Just wondering if you guys could help with a MK5 golf which I have recently picked up.
    So far I have changed the oil and filter, air filter, fuel filter and housing.
    As the title suggests I am having trouble with my golf and its tendency to be difficult to start. As it goes in the morning it will start up first go sort of, for a second or so it is really rough and shakes the car around a bit, much like it is not getting enough fuel. Once started it idles relatively smoothly. The main issue I am having is that when hot it does not like to start as well, really rough and usually doesn't catch on the first try. I have read that it may be the starter motor or battery or some ECU software where it is not injecting enough fuel when it is hot. Below is a clip I hope you guys can give me some ideas. Cheers
    Quote Originally Posted by kaiisons View Post
    Hi Guys,
    I'd suggest that you have it scanned with VCDS. It's by far the best place to start looking. When you drive it, is there excessive smoke from the exhaust at all.
    Which engine is it 103KW?
    Dec 2014
    St Clair, NSW
    No smoke at all thebonly other thing is that the engine sort of wobbles at around 1800rpm
    Has it been bad starting since you got it or only since the servicing?
    Dec 2014
    St Clair, NSW
    I've only owned it for two weeks, didn't do it in the test drive but has basically ever since
    Dec 2014
    St Clair, NSW
    and yes it is the BKD engine pretty sure.
    Dec 2008
    Sydney/Canberra
    Check battery voltage before you start it m, and also measure cranking rpm. Needs to be over 280rpm.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2014
    St Clair, NSW
    Quote Originally Posted by Umai Naa!! View Post
    Thanks for the tips Umai Naa!! I am new to these water-cooled beings. I am more familiar with their older air-cooled siblings.
    How would I check cranking RPM? Do I need some scanning cable?
    Thanks again.
    Jan 2013
    Brisbane, QLD.
    DSG? Always a good idea to remove starter motor and inspect DSG flywheel. They usually get loose after awhile causing excessive movement on startup causing hard start problems, shaking/hesitation/jerking etc.
    Also note that you will probably have a G70 crankshaft sensor fault, which will most likely be due to trying to start it over and over (dont overlook it) but just make sure it's not logged because you've been trying to crank it so long, as opposed to it actually being faulty.
    Adelaide hills, SA
    Hi Guys,
    What's your location?
