I had similar error codes in my mk5 not long ago... What tool did you use to get those codes? I thibk they are generic error codes and you need to use vcds to get more detailed errors.
Luckily after clearing the codes mine haven't resurfaced but I'm dreading the day when they return as Ill be in the same boat as you and I am unsure what the cheapest option is...
I can help you with a vcds scan if you are desperate but vw should be able to do the same.
Sent from my SM-G960F using Tapatalk
