Results 1 to 6 of 6
Thread: Water leaking into mk5 fuse box and footwell
    Apr 2013
    Question Water leaking into mk5 fuse box and footwell
    So strangely i had noticed this last time but thought i left my window down so i let it go but today again i noticed my foot well was drenched.
    I also had a look at the fuse box inside the car and noticed water around there. I checked around the sunroof, near the glass, felt the interior around the A pillar but its all dry. the water seems to be coming from around the fuse box area, going down to where the leaver to lift the bonnet is and then building up in my foot well.
    any thoughts? :S
    Dec 2008
    Sydney/Canberra
    Have you tried cleaning the sunroof drains?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    I would say sunroof drains also.
    They run down the A Pillar and out at the door hinge.
    If blocked the water can find its way along much the same path and onto the floor.
    Also the drain pipe can come out of the back of the rubber grommet nipple thing and leak into the car.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Apr 2013
    i did shove some whipper snipper cord down the hole to see if it was blocked but it kept going through. I cant seem to find a drain location that comes out near the door hinge, is it located somewhere else?
    Jul 2007
    Brissy
    Ok so it seems I gave some mis information. The drain exit is not the same as the MK4.
    They route down the A pillar and terminate under the rain tray.
    You will need to remove the rain tray & possibly the windscreen wipers to get to them
    MKV Sunroof Drain Exit Location?
    MK4 GTI - Sold
    Apr 2013
    okay so i was able to find the issue. Removing the a pillar i found that the hose that runs along the site goes into another larger hose which exits under the rain tray had come out meaning all the water was coming into my car down
    All fixed now!
