Results 1 to 10 of 14
Thread: Golf 2008 GTi service 105k ... Is it worth it ?
    Hi,
    Need some help. Just got quoted $1900 for the 105k service of the above car. Is it worth it?
    Thanks
    Chris
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by Chucky007 View Post
    Hi,
    Need some help. Just got quoted $1900 for the 105k service of the above car. I think they change the timing belts and some other big stuff. Is it worth it?
    Thanks
    Chris
    you will value the new belt replacement if you keep using the aged one and then it snaps (then new engine needed).
    Sent from my GT-I9506 using Tapatalk
    MINI Cooper S Clubman - FWD
    May 2011
    Albury, NSW
    You really need to state what that includes - for example, that's about $500 overpriced if you're only due oil, filter and timing belt kit. However if that includes brake fluid, pollen filter and water pump then I'd say it's about spot on. It's the most expensive service you'll have to do and if you're DSG then the 120k isn't much better.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Erskineville, NSW
    Hi,
    Quoted by who? Dealer, local generalist garage or Independant VW specialist?
    What have they quoted for?
    Is the car good or a POS?
    Can you do some yourself?
    It's low mileage for the age, the timing belt should have been done at around 5yrs - if so, it isn't due until 2018.
    Without knowing the service history of the vehicle it's a bit hard to help.
    It was quoted by VW dealership in castle hill @$1950 as per pic. Anybody you know who can do it cheaper the same stuff who is reliable and good? The car is real good cons. Have had no other issues since new. I'm on the north side of the bridge. Thanks for any help.
    M
    Erskineville, NSW
    So, has the timing belt been done previously? If so, you might be able to delay that.
    There's a "recommended repairers" sub forum to browse through.
    Try
    BWA at Seven Hills
    Steve Natoli (mobile mech) 0420447225
    Quixspede North Sydney
    European Autotech in Mona Vale
    RamSpeed Seven Hills
    Metro Mechanical in Marrickville
    Jan 2011
    Brisbane - QLD
    thats at least 500 more than most vw services.
    Dec 2008
    Sydney/Canberra
    It's not a cheap engine to do a belt on.
    Several pulleys to replace.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Thanks everyone. The timing belt has not been done before. Will try those businesses for a quote. Really appreciate the info.
    May 2011
    Albury, NSW
    Yeah - timing belt services are every 7 years or 105k (whichever is first) so you tick both boxes.
    If you take brake fluid out that's ~$150 - but you may be due it (every 2 Years as per VW/Audi Service Schedule)
    You might as well do the water pump, but if not, they will inspect it for seizing, leaks etc. If you opt not to do the water pump then that's about another $350 off.
    In my experience (especially in regional Australia) I'd take it to VW, as they'll do about 5-10 of these services daily, every day. Opposed to other garages that may get 1-2 a week. We've had companies here locally charge $800 more than VW have, purely because they spent the entire day guessing how to do the job (but like I said, that's regional).
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
