Results 1 to 6 of 6
Thread: MK 5 TDI EGR delete
    Oct 2015
    Brisbane QLD
    MK 5 TDI EGR delete
    Removed the EGR valve pipe
    Disconnected vacuum line to valve
    Anyone in Brisbane remove the valve electronically ? Otherwise emissions light and limp mode will happen MK 5 TDI EGR delete
    Can it be done with VCDS?
    Can't be done with VCDS. The ECU software would need to be modified.
    Oct 2015
    Brisbane QLD
    Do you know how much to do it? Know of someone in Brisbane ? How long does it take ?
    Talk to Tarmac Engineering in Cleveland. They should be able to write a new file onto the cars ECU to delete the EGR so you dont get any check engine lights.
    Bonus is that you will get a boost in power and torque (and better economy) as you may as well get a stage 1 remap done at the same time as the cost will be much the same.
    Engineered Performance - Tarmac Engineering
    2017 Ford Fiesta ST
    Otherwise a more budget option would be a tune from Superchips Bluefin. They have a EGR delete option in their tune packages for an additional fee.
    (VW) Volkswagen Golf MK5 2.0 TDI 103 kW Tune, ECU tuning, Chip Tune & Flash Tune
    2017 Ford Fiesta ST
    Oct 2015
    Brisbane QLD
    Interesting! $925 with EGR delete, looks to be the go! Thanks for the advice MK 5 TDI EGR delete keep you updated
