When was the trans oil last changed?
Sent from my LG-D802T using Tapatalk
I have a 2007 Golf Comfortline 2.0 TDI 6 speed manual.
The transmission makes a resonance at 60KPH in 4th gear.
It is like a vibration or throbbing sound which fades as you slow.
I recently had the RH drive shaft replaced as the joint failed. The left one is original.
I have owed the car from new. No 212,000Km. Serviced without missing an interval.
Timing belts changed.
Any ideas about my noise? It has been there for a long time but seems to be more pronounced lately.
2.0TDI Comfortline, Candy White, Sun Roof, Leather, SATNAV, Bluetooth, 6 Speed Manual
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Update: noise was coming from transmission. Bearings and synchro rings replaced. Very costly.
An expensive repair on a manual hey, and the DSG is considered the problem child
Can you elaborate on 'costly' for us, this detail may add some value for the next punter that comes along.
MK4 GTI - Sold
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
I was told by the transmission specialist that to remove & refit the transmission would be $500 plus parts to effect the repair. Final bill ran out to $2,750! That was using VW Genuine parts. This guy really knew his stuff but he couldn't explain why or how this happened. He was surprised that the gearbox failed at 220,000 km.
Thanks for the reply, and OUCH! I will suggest to the wife that she be gentle with the gearbox.
It's an unusual failure indeed.
Not that common these days for a manual gearbox failure in a VW.
