Try Bosch auto shop online. About $60 a set.
Anyone know where I can get replacement windscreen wiper blades to fit my 2010 Jetta, cheaper than $140 the pair at my
VW Dealer /Workshop?
MY20 Golf GTI TCR
MY20.5 LR Defender P400 HSE
Surely your VW dealer can supply just the rubber inserts!
My local (SE Melbourne) sells the inserts for about $45 pair including two replacement end clips and I just carefully unclip one end and slide out the old and in the new and put the new clip on.
I hope you can get some at a decent price then!
BeigeJet
White MY23 Tiguan 147 TDI Elegance (mine)
White MY21 Tiguan 147 TDI Elegance (wife)
Gone - Wheat Beige MY07 Jetta TDI manual
Inserts were $12ea at the old dealership I was at.
Tiguan, and Later 3C Passats had non-replacable inserts in them. You had to replace the whole blade at $80 a side.
Not sure wheather the later 1K Jettas had replaceable inserts like the Golfs did.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I bought mine (MKV R32) from here:
https://www.wipertech.com.au
Quick delivery..... perfect fit.
+2 for wipertech. Used a few times now on various cars, seamless and reasonably priced. Have bought from them via Ebay.
Gone: 2009 MkV GTI DSG United Grey; 2005 MkV Comfortline
Current Rides: 2020 Mk7.5 GTI Performance ; 2013 MY14 V6 Touareg 180TDI
Get a set of Tridon steel back blades in the narrow style. They're about $14 at Supercheap. Throw away the steel and keep the rubber. Work off one end of the original blade with a small screwdriver. (you will need to look where to place the screwdriver as there's a small retaining clip) Once the end is off, remove the old blade, replace with the new, cut to length and clip the end retainer back on. I did this recently to an 06 Jetta and they work as good as new.
Numerous Mk1 Golf diesels
I've bought Bosch Aero via ebay UK seller for ~$50
Well after 9 years was time to replace blades , got stung by VW after 12 months of ownership and charging $50 each.
No luck at Supacheap unless I paid the $39 each for full curved blade , went over the road to Auto barn and they had just the blade incert
similar to the old one , just a little thicker at top , took a bit of careful coaxing but got it on nicely , simple procedure , now works a treat
and only $10 a blade.
