unless you optioned sat nav (from factory, not dealer fitted) you will get the midline cluster on the comfortline (midline). the highline cluster does not seem to be a stand alone option in australia - even so, if it were available as an option the dealer would have asked you if you wanted one - more options added likely earns more dealer brownie points.
the sportline should represent the euro highline models, so you should get a highline cluster.
hope this is accurate![]()
