Is it the rivets that have failed?
Might be worth having an engineering shop replace them with bolts in the future.
So a friend of mine has this problem, can anyone suggest something ? any help would be appreciated thanks
"I have a Golf mk5 2008 1.6FSI Match with a JHY gearbox and while driving the crownwheel and pinion had gone with only 30,000miles. After a quick research I realized that it's a common problem, and even if I but new parts(O2T crownwheel and pinion alone cost approx 700 euros) and replace them, it may fail again. I was thinking of changing the gearbox even if it's 5-speed, maybe I solve the problem but am not sure what gearboxes fit or if the problem is solved. What do you suggest?"
'07 Transporter 1.9 TDI
'01 Beetle 2.0
G5 5 speed gearboxes are leftover from golf 4.Just throw in a s/h one and fingers crossed.
You can buy a cw bolt kit from any dealer.
No not the rivets that failed, the tooth of the crown wheel and the pinion 3 teeth each all gone and its making a big rumble noise, they cost alot to replace so im just checking if there's any solution, might fit another gearbox or something.
