Results 1 to 7 of 7
Thread: Steering rack replacement?
    Sep 2017
    VIC
    And the list continues...
    My r32 still tracks to the left I took it in for a quick look at Volkwerke. He noticed the dreaded knock in the rack and is fairly confident that's causing my alignment issues. Going in this week to get the final call. I have noticed the steering lately is getting heavier, another symptom?
    What pisses me off is I just replaced the LCA bushes and got a dead set kit, which according to a reputable suspension shop fixed the alignment issue, however if the rack was on its way out it was essentially a waste of money as it was the rack all along?
    Checked etka I have gen 2 rack. Called VW for ****s and giggles $1700 with swap over. Vokwerke circa $2500 fitted but again going in next week for final assessment.
    Interesting enough online can get a gen 3 rack for roughly $700 new from UK. Will this fit the R32? Checked twice just want to be sure. I can source the new harness too for $120.
    Sent from my C6603 using Tapatalk
    Apr 2008
    Quote Originally Posted by spec32 View Post
    Have you asked Volkwerke, or anyone, to replace the thrust pieces?
    I replaced my rack after it was noisy AF with one from an R32
    It’s quiet but has too much resistance. A mate and I pulled my old one apart. We removed the thrust pieces, lubed them up and put them back in, knock disappeared.
    I’m going to go down that path with my current rack in the near future
    Quote Originally Posted by benough View Post
    Really interesting whilst rolling through all the posts I havent seen that mentioned. I will mention that to Volkwerke could save me a whole new rack.
    Apr 2008
    Hi everyone just reviving this quick.
    Quick question will any MK6 golf steering rack retrofit on MK5 R32?
    Told to not bother as if its say from a wreck you don't know its condition? but surely if you re-furb the MK6 rack and get the new harness its cheaper than getting a Gen 2 rack new plus replacement?
    I let it go for ages but now my dreaded knock is getting louder so its only a matter of time before it goes completely caput
    Apr 2018
    Hi spec 32 my mark V 32 had a clunking noise coming from what I thought was the steering rack, I took it to VW Village at Kensington they inspected the rack appeared ok but they found most of the bolts that all the steering and front end together were loose, after tightening these 95 percent of the noise went, Bill told me that the bearings at the top of struts wear and can even fall out which can also cause the same noise. Goodluck
    Quote Originally Posted by notso View Post
    had it assessed by a few places now, my strut bearings have been replaced. When car is stationary and turned off its more audible definite steering knock.
    Called around and most power steering rack places I have called around say dont bother re-furb the rack as the rack itself is discontinued so looking at second hand gen 3 rack
