Results 1 to 2 of 2
Thread: EGR problems....again!!!
metako EGR problems....again!!! 21-09-2023, 06:51 PM
metako I went to Imlachs self... 22-09-2023, 05:32 PM
    Jun 2013
    Our 2.0 FSI was coughing or stumbling at random times today, so I removed the EGR valve cover and sure enough there were broken teeth on the black plastic "half-wheel" cog. I'd replaced the "full-wheel" cog last year with a new, improved one from Germany which was easy enough, but the "half-wheel" is attached to a big spring underneath, and doesn't look like it just pulls off.
    Has anyone taked this cog/wheel off without taking the whole EGR valve off?
    Attached Thumbnails Attached Thumbnails EGR problems....again!!!-egr-broken-half-wheel-2-jpg   EGR problems....again!!!-egr-broken-half-wheel-1-jpg
    Jun 2013
    I went to Imlachs self service wreckers today to see if I could find a good SH EGR valve. I could only find one MkV 2.0 FSI despite there being 5 listed (its very hard to find specific cars at Imlachs as they don't group them together very well). The one I did find had an EGR with a broken "half-wheel" like mine.
    So as the EGR was of no use to anyone, I tried to pry the plastic "half-wheel" off with 2 hefty screwdrivers and it just broke apart. I had to use a screwdriver and hammer to hammer the rest of the plastic wheel from the shaft - it seemed to be either a very tight interference fit or heated up when fitted so that it clamped on tight when it cooled. So its nothing like the "full-wheel" cog, which can be just lifted out easily, and not user-replaceable unless you experiment with heating it up somehow. There are a few repair videos on youtube where people attach toothed metal plates to the broken wheel or glue in a single metal replacement tooth, but who knows how long these will last.
    So I'll try a few more self-service wreckers over the next couple of weeks to see if I can find a good SH one, or even 2 as they are all near the end of their service life.
    Attached Thumbnails Attached Thumbnails EGR problems....again!!!-egr-cog-removed-1-jpg   EGR problems....again!!!-egr-cog-removed-2-jpg
