If this has happened imediately after haveing work on the exhaust id check first any connections to the exhaust - make sure everything got plugged back in - Though I would expect to more faults.
I cant reccomend a genuine Ross Tech Hex CAN or what ever the current version is - Yep its about $400 but makes life a lot easier.
You will get a lot more information about the faults plus probably a whole lot more.
Your Evap fault could be Too much flow - Vacuum leak, or crud in the valve. It could be the valve not opening -faulty solenoid or blocked pipe.
I believe there is a filter in the Evap canister that can become blocked.
