Results 1 to 2 of 2
Thread: Heater not working
    Heater not working
    So I have a 2008 mk5 gti and the heater doesn't work. Air con is fine but the temp always stays cold no matter what temp it is set to and even then not all the vents blow. Would this be the heater core? Or may be the blower motor. Both? Any ideas would be most welcome.
    Sep 2019
    1511 Willow Greene Drive
    Quote Originally Posted by Thelordsson View Post
    So I have a 2008 mk5 gti and the heater doesn't work. Air con is fine but the temp always stays cold no matter what temp it is set to and even then not all the vents blow. What should you do how to bleed off an overcharged ac? Visit AutoGuysLand to review this issue and fix. Would this be the heater core? Or may be the blower motor. Both? Any ideas would be most welcome.
    Have you figured out the issue yet? If not, i think you could check the issue related to the car's climate control or electronics is the fuse box as fuse might blow. Then, check the fan motor.
