Results 1 to 9 of 9
Thread: VCDS coding problem or something else
    Hi, first real post....so here goes, had an evap lower limit fail that I managed to fix by replacing the N80 valve and hose myself, (happy with that) but a few months ago I had an issue with a constant battery drain, that turned out to be a water damaged electric door module on drivers side. This was replaced and all seemed well.
    Until I got my VCDS cable and fixed the evap problem I wasnt aware that there was an issue with the safe motor on both front doors. I understand what this motor does but I believe the electric window module replaced wasn't coded in the shop properly so I would like to ask what It should be coded to on a MkV GTI my08 (German built).
    I will try and attach my latest scan, I have also just tried to code it as 1680, to see if that helps....but I believe that it does have a safe motor installed correct?
    Thanks for any responses
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72
    VIN: WVWZZZxxx Mileage: 58980km/36648miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: VWX7Z0G43NN880
    Coding: 040300431C070160
    Shop #: WSC 66565 257 00032
    VCID: 346318E32EAB
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
    Component: GSG DSG 081 1305
    Revision: 04508010 Serial number: 00000704240216
    Coding: 0000020
    Shop #: WSC 44551 111 44551
    VCID: 224FEEBB845F
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0004738
    Shop #: WSC 00046 412 00000
    VCID: 73E1DBFF6B25
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
    Component: ClimatronicPQ35 120 1111
    Revision: 00120021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 79FDE9D74949
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007100958
    Coding: E58D8F2700041500471400001400000000087F075C00010000 0000000000
    VCID: 71EDD1F71139
    Part No: 1K2 955 119 E
    Component: Wischer 120707 020 0501
    Coding: 00049109
    Shop #: WSC 00046
    Part No: 1K0 955 559 AB
    Component: RLS 070507 020 0105
    Coding: 00208933
    Shop #: WSC 00046
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1P AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD160U00
    Coding: 0012624
    VCID: 3D753DC71DE1
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
    Component: J0527 636 0070
    Coding: 0012122
    VCID: 810D0137A199
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K6 920 874 HW: 1K6 920 874
    Component: KOMBIINSTRUMENT VDD 1216
    Revision: V0002000 Serial number: VWX7Z0G43NN880
    Coding: 0003103
    Shop #: WSC 60074 959 65905
    VCID: F0EB54F39A33
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 040607F1001408
    Coding: ED807F065002020003
    Shop #: WSC 60074 959 93514
    VCID: 306B14F3DAB3
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1216
    VCID: F0EB54F39A33
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
    Component: RNS-MID H11 3970
    Revision: AB001001 Serial number: VWZ6Z7Z5604521
    Coding: 08010000010000020000
    Shop #: WSC 42595 146 50733
    ASAM Dataset: ------------------------- ------
    VCID: 2F69178FC78D
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 120B
    Coding: 0000640
    VCID: 387B2CD332C3
    1 Fault Found:
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
    012 - Electrical Fault in Circuit
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    VCID: 366722EB38D7
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002005103087F2D04840570085FC690FC00
    VCID: 83010B3FBB85
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Component: Innenraumueberw.003 0203
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No: 1K6 035 456 A
    Component: 08K Audioverst. 0005
    Revision: 00003000 Serial number: 00000000136227
    VCID: 2A5F069BFC6F
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Component: Tuer-SG 005 090B
    Coding: 0000640
    VCID: 397D29D709C9
    1 Fault Found:
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    012 - Electrical Fault in Circuit - Intermittent
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    VCID: 2F69178FC78D
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1201
    Coding: 0000144
    Shop #: WSC 00046 412 1012557
    VCID: 387B2CD332C3
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 HW: 5K0 959 704
    Component: Tuer-SG 007 2106
    Coding: 0000144
    VCID: F2EF5EFB943F
    End ---------------------------------------------------------------------
    3 days later the main fault came back p0441 - 002 lower limit exceeded
    someone also suggested the N75 valve Volkswagen Golf V 2.0T > Search > N75 > ES#257544 Waste Gate Frequency Control Valve (N75 Valve) - 06F906283F
    or pipes around charcoal canister (checked) or the canister itself, any ideas? am I in the correct forum here?? or is it "nobody knowwwss"
    Dec 2008
    Sydney/Canberra
    In regards to the door module, has it been basic set? Does the window on that do auto up/down?
    Also, check for broken wires where the wiring passes from the A-pillar, though to the door.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Hi, sorry for late response, yes the window goes auto up/down, basic set? is that the tests you can run from vcds...yes I think I did run that.
    cheers
    Jul 2011
    Check your coding on the other front they should be the same !!!
    Sent from my iPhone using my fingers.
    unfortunately fault shows up on the other door also, I don't remember what the original coding was, if it's a genuine fault or if it was due to my messing.
    If anyone can tell me what the original coding should be for my car that would be super fantastic, then I could code both doors and see if the fault is related to dodgy replacement of the module (I reckon it probably is I took it to the RAC )
    Jul 2011
    Attach a print out of door lock modules coding via vcds.
    I must be tired but how can I attach a screenshot here?
    ---------- Post added 12-02-2012 at 11:24 AM ---------- Previous post was 11-02-2012 at 11:11 PM ----------
    ---------- Post added at 03:43 PM ---------- Previous post was at 11:24 AM ----------
    need to put this issue on the back burner, thanks for responses....
    car made a crazy loud screeching noise last night, RAC guy came out and looked this morning, said I need to tow it to VW looks like the drive belt tensioner or timing belt tensioner, thing is I had strange issues when the car only had 37K on it and VW replaced timing belt (iv seen this on youtube) and other belts back then on warranty.
    Also car just had it's 60km service few weeks ago and when he checked the oil this morning it was on minimum! I know the 2ltr FSI burns oil but surely not this badly, that's another issue It's been a great car though with very little issues
    ---------- Post added at 05:54 PM ---------- Previous post was at 03:43 PM ----------
    mmmm after some research, I think the RAC guy may be wrong, it may be the PCV valve from what I have read on all the forums its sounds similar
    EVAP, oil usage and the noise may all be related to this one little valve, btw I know nothing about cars and engines, so just guessing here, Im not sure if I take it to the stealer or just try and fix it myself, does anyone have a part number for a new valve?
    Was a bearing that sheared on the timing belt tensioner!
