Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Euro plate mounting?
    Feb 2007
    SE QLD
    I noticed on a set of euro plates that were ordered in for a Benz customer at my dealership that there are no holes drilled at all in the plates. For those of you with euro plates, how did you mount them? Double-sided tape maybe? Or how many holes did you drill into them?
    Furthermore, on the Mk5, what are the normal mounting holes for euro plates, both front and rear? I hope it's not through the middle like on some cars?!?
    The Germans use plate holders that screw to the car using the bosses fitted by the manufacturer. The metal plates then fit inside the holders.
    I reckon if you have a look on ebay.de you'll find some.
    http://cgi.ebay.de/Exclusiv-Kennzeic...QQcmdZViewItem
    http://cgi.ebay.de/Kennzeichenhalter...QQcmdZViewItem
    Point Cook, Vic
    yeah i got some plate holders for mine. the holder screws to the car and the plates slot in then u put a cover over the bottom bit. saves drilling holes in your stupidly overpriced plates
    FOLLOW US ON FACEBOOK
    Go with the plate holders m8
    mk3 GTI 16v 3dr
    Nov 2006
    Canberra, Australia
    Don't be such a nancy boy, just drill 'em straight into your bumper.
    The MINI has mounts in the middle of the rear plates which is a bit pants.
    MY10 S3 3dr
    syncro Guest
    I just drilled two holes in the centre which lined up with the genuine VAG holes.
    Feb 2007
    SE QLD
    Syncro, when you say you drilled the centre, was it in about the position where I've marked on this euro plate by the red dots?
    Sep 2006
    Parkinson / Brisbane
    It might sound dodgy, but seriously just use good double sided tape! I have two mates that work for Audi/Lamborgini/Ferrari and they use double sided tape for all of those cars! Trust me if you do it right IT WONT COME OFF!!
    LS1 Cobra Guest
    The dealer just drilled a couple of ragged holes in my plates and bolted them on to the standard bosses. Not impressed.
    I drilled new holes in the boot lid and installed stainless steel nutserts in the right locations. The front plate had been attached with a couple of self tappers straight into the chrome bumper. I drilled the holes out and put stainless nutserts in the front too.
    BMW007 Guest
    Quote Originally Posted by Tim View Post
    Hey Tim.. can you clarify for me the following.. if the plates simply sit inside the cover and the cover is what is scrwed onto the car, doesnt this mean that the plates can be stolen by simply just opening the cover and taking out the plate?
    Also i assume the cover you have is the same as...
    http://www.autogeek.net/gerplatfram.html
