Results 1 to 10 of 14
Thread: replacing a head unit
    Aug 2011
    brisbane
    I know this topic comes up time and time again, but it is still confusing to me.
    my kids have had and still have mk5's. Jetta's, gti's and tdi's, 06' to 08's.
    they are wanting to upgrade to a Bluetooth(for phone and music) head unit,
    whether it be genuine or after market. the issues with battery drain, canbus
    upgrades, gateway's, differences between year models etc, just confuse me too much.
    is there any literature to read that explains it all, or is there someone in Brisbane
    I can speak to, to get some direction on what the best option is.
    I don't understand why you can't just pick up a hot active and a switched active like
    iv'e always done on other cars.
    The issue with putting in a newer generation head unit into a car earlier than around 2008 is that there is a network switch, known as the CANbus gateway that in newer head units cuts power 30mins after shutdown.
    This allows the head unit to start instantly if you go into the service station to pay, instead of going through the whole bootup sequence (which in an older RNS510 can be a bit lengthy).
    So if you have an older gateway that doesn't shut the head unit down after the car is turned off, it will quickly drain the battery.
    If the car is pre 2008 (you can actually check the gateway part number and if it ends in L or later then it's OK) then you will likely need to upgrade the gateway.
    Aug 2011
    brisbane
    thanks for the info.
    so, where can i find the gateway number, and who can do the upgrade?
    and once this is done, can any late model or after market unit be used?
    The gateway will show up on a scan of the vehicle with diagnostics software (which will also be needed to code the new gateway to match your current config).
    The module itself is in a difficult to get to position up above and behind the steering column (or one of a couple of other places, they kept moving it around in different cars and years).
    Once you have replaced it with a newer version then any newer stereo can be used.
    I'm sure there are plenty of people in Brisbane that can do it for you for cash/beer.
    Jul 2007
    Brissy
    I added a Sony unit to my Jettas. I did not need a CAN upgrade.
    I got a steering wheel control box so the volume & mute buttons still work.
    Connects2 Ltd
    Needed a connector for the antenna, "Dual Fakra to Standard DIN Male (FM Diversity)" ebay
    looks like you can get this bundled with steering control now too.
    Connects2 Ltd
    Lastly was an adapter for the Sony unit to the ISO connector that VW use.
    Aerpro Wiring Harness - suit Sony Head Units 2013+, APP8SP3 | Supercheap Auto
    I also went to single DIN, so I got a fascia plate which gave a pocket below the radio.
    Connects2 Ltd
    You will need brand specific ISO adapter and the patch cable for the steering wheel controller.
    No wires were cut, everything worked just fine.
    First car took about 1 hour, 2nd car about 20 minutes.
    Internet research about 3 days
    replacing a head unit-20160613_202733-jpg
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2011
    brisbane
    ok, so are the jetta's early or late models, and, is the canbus issue only for original equipment?
    Jul 2007
    Brissy
    Mine were both 2006 models, so early.
    MK4 GTI - Sold
    Aug 2011
    brisbane
    Hmmm, might have to take the punt and try an aftermarket unit first, and see what happens. thanks!
    May 2017
    Without going into too much detail - a foolproof way of getting Bluetooth, nav etc. in any Mk5 Golf is to buy one of these:
    RCD330 Plus RCD330G Carplay Android Auto Noname 6RD 035 187B Car Radio MIB For VW Golf 5 6 Jetta MK5 MK6 CC Tiguan Passat Polo-in Car Radios from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group and one of these:
    BODENLA RCD330 Plug&Play ISO Quadlock Adapter Cable w/ CANBUS Decoder Simulator For VW Golf 6 Jetta MK5 MK6 Passat Polo Vento-in Cables, Adapters & Sockets from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
    I'm a big fan of the RCD330 head unit, and lots of members on this forum use them; you can buy models without the Android Auto/Carplay functions for a fifth of the price, too. The Canbus decoder module saves you having to replace the Canbus unit (can confirm from personal experience that it works!), and the whole thing is a half-hour long plug-and-play install. Can't recommend it enough!!
    Aug 2011
    brisbane
    Quote Originally Posted by maltbbe View Post
    awesome, will go down this path i think!
