Results 1 to 2 of 2
Thread: Golf R32 O2 sensors
    Jan 2021
    sydney
    Golf R32 O2 sensors
    Hey all
    Have a golf R32 2008
    Thanks for the add on this forum. I've been told there are 4 O2 sensors and some of them are playing up.
    The error codes:
    P0430 - Catalyst system, Bank 2 Efficiency below threshold lower limit not reached (Intermittent)
    P0420 - Catalyst system, Bank 2 Efficiency below threshold lower limit not reached (Intermittent)
    P0441 -Evap Emission contr.sys incorrect purge flow Lower limit not reached. (Intermittent)
    So from my understanding theres an issue with the sensors but unsure which out of the 4? Or rather just change them all? Or is there a maintenance method such as cleaning the sensors if possible.
    Apologies if this has been asked before.
    Thanks
    Ezat
    Have you still got Cats installed? These are the rear probes that are faulting. Decatting needs a tune update to prevent this. If you still have cats, then maybe new probes will be the cure.
    The Evap canister is the other fault. That or the N80 valve which allows the fumes to enter the manifold.
