Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: DIY: How to repair a VW MK5 door lock module
    Hi this is a great write up!
    I’ve been trying to repair my own door locks but no having much success.
    Got a Golf Mk5 2004 (1.6 FSI - BAG engine code).
    Wiring harness looked good and checked the door jam area as they are known for them going there. Couldn’t find any broken wires.
    Stripped the lock down and cleaned out motors and polished commutator with sandpaper as shown in the guide.
    But the door lock doesn’t lock and unlock as it should.
    Any ideas what I should do?
    Thanks
    May 2016
    Melbourne, Victoria
    Are you hearing any noise from inside the door when trying to lock/unlock and have you scanned the car for any faults?
    2016 GTI 40 Years | 2012 Up! | 2006 Jetta - Sold
    Yes I’ve got VCDS / VAG COM....will do a scan and report back to you.
    It was making noises...from what I could tell.
    Before I started fiddling the door remained permanently open and wouldn’t lock.
    Now it appears to to be permanently locked and won’t open....
    Not sure what to do?
    Jul 2007
    Brissy
    Try to open from the inside. The electronic motor is used to lock and unlock for the remote. Pulling the internal handle should unlock mechanically.
    Just relace the lock, there are many aftermarket options huge price range too.
    The cheaper ones do work, but I have found 1 of 3 I purchased does not do deadlock mode, It always opens from the inside which is a pain as due to the heat over here leaving the windows partially down can be a nice thing.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Managed to get door back open and have stripped it all down again.
    Still a bit clueless as to why it isn’t locking / unlocking. It looks as if it gets stuck in the locked position for whatever reason.
    I’ve attempted to inspect the circuit board for bad solder joints but can’t see anything obvious. I know these can be very subtle so I may have missed something.
    Now starting to suspect dodgy wiring from the window control unit to door lock, or in the door jam area.
    Here is my VCDS scan,
    Code:
    Saturday,05,December,2020,18:32:59:33544
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 20.4.2.0 (x64)
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 351740km-218561miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B09E6E-8036
    No fault code found.
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC91561D-806E
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C5B689-8032
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C3EE2-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21D66D-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B06A3-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CBE72-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DF6B1-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A66685E46-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    3 Faults Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    00931 - Locking Module for Central Locking; Rear Right (F223)
                012 - Electrical Fault in Circuit
    01038 - Central Locking Thermal Protection
                000 - -
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA520EAC-8064
    1 Fault Found:
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
                008 - Implausible Signal
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236EE88-8078
    End-------------------------(Elapsed Time: 01:34)--------------------------
    Mar 2009
    Goulburn NSW
    The implausible signal implies that the signal sent back to the door control module is not what the module is expecting - for example, its expecting the door to be open but the signal is saying its closed. That in conjunction with the 01038 Central locking thermal protection which appears to indicate that the door module is not getting a message to stop the motor and the driver is overheating due to a stalled motor.
    checking the operation of the micro switches would be a good place to start.
    from memory the drivers door has 3.
    1 door open/closed
    2 lock active
    3 unlock signal (from using the key)
    the other doors only have 2.
    There are some you tube clips on replacing and testing the switches.
    Interestingly it appears faulty switches seem to be more prevalent in the UK and in Aus its the motors..... Just my observation.
