Originally Posted by
Lucas_R
Sounds to me that either....
1) The timing belt was installed incorrectly and the timing was out causing damage to the valve(s).
2) The timing belt and/or tensioner/bearing/idler/water pump etc failed prematurely (or was not installed correctly) causing the sudden noise and breakdown several weeks after having the work done.
Note that with option 1 above that if the belt was installed incorrectly i would have expected the following to have happened which you would have noticed:
- Damage to have occurred earlier than it did and/or possible noise from valve hitting the piston.
- Car to have felt sluggish to drive as timing was out.
Sounds like a mess unfortunately and lots of money coming out of your pocket for a car that is lucky to be worth $8k being 13 years old with 200+Kms. I would grab an engine from a wrecker to get it moving again and either sell it or keep driving it until it dies.
Also, please stop taking cars that are well out of warranty to a VW dealership to be serviced. You are paying absolute top dollar for an old car to be worked on by an apprentice mechanic. You will save hundreds going to an independent VW specialist mechanic and in the vast majority of cases, get a better level of service.
