Results 1 to 9 of 9
Thread: can turn on headunit w/o key in ???
    Nov 2007
    this is funny! w/o even having my car key in the ignition at all, i can just turn on the headunit, is this a fault? never have this on any other cars i have before, what if you done that and leave it on overnite, the battery will drain dead, isn't it? can i config this to be on only with my key in?
    Nov 2006
    All late VW/Audis do it - I believe it will turn it off after one hour to save your battery tho
    Dec 2007
    BNE
    well this is common to many euro cars.
    i don't think you can config it to be on with key only unless you redo your wiring.
    Aug 2007
    Perth, Australia
    yup, common with europeans, and it does turn off after a while (1 hour i think)
    1991 BMW 318is RED E30
    Wollongong, NSW
    Yep my old Peugeot does the same thing.
    R32 MY08 3Dr
    Deep Blue Pearl DSG
    Haldex Gen 2 + Switch Neuspeed TAI Whiteline 24mm RSB and BSH Endlinks
    Forge intake Alpine/Focal ICE
    Nov 2006
    Actually now that I think of it - AU/BA/BF falcons all do this too.
    Jun 2007
    It's so yo can take your key, but leave someone the radio (I guess).
    Though, be careful if you remotely lock the car as the passenger can listen to the radio but not open the car.
    Sydney (Close to CBD)
    this was true on my 99 Vectra as well. The head unit can be operated for an hour without the ignition being on and then it will cut out automatically. You can then restart again if you really want to.....
    Jun 2007
    To be an echo, yep, most Euros do this. My old Land Rover Freelander used to have it as well (it'd say "1 Hour" on the display too).
    07 Jetta TFSI | 18" Charlestons | Blue Graphite
