Results 1 to 10 of 10
Thread: can RCD500 direct replace RCD300?
    Aug 2009
    Sydney,NSW
    hi all, just quick question. can rcd500 direct plug and play on 05 golf?my rcd300 is broke and just need to find one that can direct replace. any other model can fit too. thanks
    Apr 2009
    it's my understanding that you can replace the same series radios with each other.
    ie: RCD300=>RCD500 should be ok
    RCD310=>RCD510 should work.
    where you have difficulties is with RCD300=>RCD510
    i have my old RCD300 unit if it's any good to you ?
    i don't need it any more.
    Jason.
    05 Golf 1.9 TDI comfortline DSG
    Dec 2008
    any of the RCD's should fit without a issue. I swapped a RCD500 with a 310 for the MP3.
    I've got my RCD 500 here for sale if your interested.... 6 stack but no mp3
    Apr 2009
    of course the units will physically fit, but as you should be aware, swapping from an older unit to the newer ones CAN lead to the battery drain issue.
    that's why i said stick to the same series unit and it should be ok.
    Jason.
    Aug 2009
    Sydney,NSW
    Quote Originally Posted by 85turbo View Post
    Jason.
    thanks and is your rcd300 for sale?howmuch you looking?
    Apr 2009
    you can have it for free if you come collect it.
    i cant drive yet.(have not been given clearance from my Dr yet)
    Jason.
    Edit:
    send me a PM if you want the unit and ill give you details of my address and what times are good.
    it's wrapped in the bubble wrap that my RCD510 came in.
    i have the book and the code too.
    Dec 2008
    http://www.my-gti.com/719/difference...nd-the-rns-510
    (thanks to mav!)
    there is also the sound fix, and info about the can bus on that site as well.
    Apr 2009
    Pow.
    i sent u a PM.
    Jason.
    Hey i got a RCD500 which is 6 stacker and mp3 and ipod and aux connection
    if thats what you are looking for
    http://www.vwwatercooled.org.au/newf...ad.php?t=34589
    Dec 2008
    Sydney/Canberra
    In regards to fitment, take note of what car it's going into, and conversly, what car it came from.
    Transporter/Multivan and Touareg have a different mounting setup to Polo/Caddy/Golf/Passat/Tiguan/Jetta/Scirrocco.
