Results 1 to 10 of 17
Thread: Calling all Mk5 GTI drivers with Denvers
    Albion QLD
    When you bought your car, did it pull to the left?
    As some of you may know, I swapped with a mate the other day with a mate and I now have Denvers on my MY08 Jetta. The other day when I got the new tyres they did the alignment and it now pulls to the left. I went back to the place today and they say that it's nothing they can do as it's the way the Castors are set up. I went on to explain that both with my stock Atlantas and my after market 18s I didn't have the problem but they didn't budge at the fact that it's "the way the car was made".
    Any thoughts?
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
    Jun 2009
    I believe the GTI was set up with a negative camber setting of half a degree so that may be causing your uneven pull.
    Not 100% sure on this however, JMAC may be able to help with the issue.
    Edit:
    Just found this http://www.mkv-gti.net/wiki/index.php?title=Suspension
    Second heading form the bottom outlines the camber, toe and caster specs for the MK5 GTI.
    Albion QLD
    Quote Originally Posted by team_v View Post
    Edit:
    Ok thanks, I'll check it out and if I need to I'll call Jimmy.
    Just find it hard to believe that I never had a problem with my Atlantas or 18 Lavinhards, then all of a sudden I got this problem.
    Would the specs be the same even though I have a Jetta?
    Albion QLD
    Sorry I may have worded it wrong - if I let the wheel go it doesn't actually pull to the left, if the steering wheel is physically straight the wheel point to the left a little..
    Jun 2009
    Quote Originally Posted by maca View Post
    If they are OEM wheels then they would probably be designed for the GTI setup.
    Since the Jetta shouldn't have the same setup as the GTI, it could explain why the wheels are "pointing to the left"
    It could also explain why you didn't have a problem with the other aftermarke twheels as they wouldn't be setup for specifically for the GTI.
    You could probably resolve the issue by getting replica Denver's.
    Nov 2006
    lol.
    This is adjustable, they must have ****ed it up when they did the alignment. Happened to me once. Wheel was WAY out. Wheels have nothing to do with it.
    Jan 2008
    The wheels will work fine on the Jetta sounds more like the alignment has been screwed up.
    Buying cheap replicas isn't going to fix the problem.
    Nov 2007
    Perth
    go to another alignment place.
    what a joke.
    Who is messing with my profile?
    Quote Originally Posted by SoVeReIgN View Post
    lol.
    +1, take it back to the aligners - or someone decent form a change (but will cost you extra) - and get it fixed by them gratis.
    Feb 2009
    Tell us where it was Maca,
    SO WE CAN ALL AVOID THE PLACE!!!!
