I might have part 1will check later and post back here
Unfortunately my scanner is broken![]()
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
.... And so much for the simplicity of diesels
There's just so much that can (and eventually will) go wrong! Thank God for:
Can you imagine the cost of replacing some of these parts????
- A 3 year warranty (but what about after that? An extended warranty?)
- My old Mk1 GLD in the shed
Thanks jets and maris. You've done well. Now to the printer! Phaeton... find part 1 and fix your scanner. Might as well have some more scary stuff![]()
LOL Brackie
I do have part 1![]()
- Ben
2008 Jetta 2.0L FSI
Top article, thanks for making it available.
Interestingly enough, if the cruise control is engaged and you change gears say from 5th to 6th, there is a ( slight ) surge in the rpm.
According to the information ( if I have interpreted it correctly ) this should not happen ?
Have now travelled 5,300 ks in the 1st month of ownership - what a car !
cheers
richo
2007 2.0TDI Golf
Seems to be good enough for us too. I am SO far from fully understanding diesel, I am not really fussed, seems to go alright.
I've only just started using cruise regularly (12750km) and yes, I experience the surge but in other gears too. I find that as I set the speed there is a surge to a speed slightly above where I want it to be. My wife had a Mazda 929 and it did exactly the same thing. When I had the TDI's ECU reprogrammed to solve the battery flattening problem I asked the techie about it and he said it wasn't normal but couldn't find why it happened.
Cruise is good, that's for sure. Certainly was useful on a trip to Sydney, particularly being able to accelerate and then back off to the set speed.
I'll be interested to see the first part of the article posted.
cheers
richo
Psst........did I tell you how much I enjoy driving the Golf![]()
