In 103kw form, the MKV TDI's had no DPF's ( exhaust particulate filter ) so around town is no problem. In MK6 guise they do, but it is a different DPF to the combined MKV one, and it "should" clog up less. Depends on what model you are considering as to what it is limited to. The 6 speed sits just over 2000rpm in 5th at 100kph, I rarely use 6th as it drops it down towards 1800rpm which is the lower limit of useful boost and soot avoidance, but then I do have the MKV 125kw with a DPF. The manual is very busy around townm and you have to get used to making a lot of changes, a BIG difference I found coming from a big auto, but a welcome one.
2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside cams | Darkside dump pDPF | Wagner Comp IC | Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Michelin 4s | Golf R subframe | Superpro sway and bushings | 034 engine mounts | MK6 GTI brakes.
