Workshop rates plus admin charge. Not unreasonable.
If you were servicing your car there they’d probably do it for free at the time.
So rang a place was told 50 to plug in and 150 an hour, and roughly takes an hours to check things, am I just stingy or is this robbery since I can buy one for 379
What are you wanting to do on the car?
You can buy a rip off VCDS for under $100 which is what I have now (i used to have a real one but sold it a few years back, cant justify the price now). Unless your car is brand spanking new then the fact that it runs software that is about 18 months old wont be a problem (certainly no problem on my 2015 model car) as you cannot update the software.
** Edited **
Or you can buy either OBDEleven or Carista. OBDEleven can do probably 85% of the full VCDS, whereas Carista is much more basic (hence the cheap price) but is fine if all you want to do is check error codes and make very simple changes to the car.
OBDeleven V2 Pro Pack – Audi, Skoda & Volkswagen Diagnostics – AutoInstruct
Carista OBD2 Diagnostic Scanner and Customiser for Android and iOS – AutoInstruct
2017 Ford Fiesta ST
Yes it does, its the genuine software but the cable is a fake - therefore the only drawbacks are:
- software cannot be updated (because it will recognise the cable is a fake and corrupt it). For this reason i suggest getting the V18.9 software which isnt that old.
- wifi must be turned off before you use the cable otherwise it will try to do a software update automatically.
If you remember these two points then its all good. Ive had mine for nearly a year now and used it probably 10 times with no issues.
I know there are other members on here using the same cable too - so im not the only one.
2017 Ford Fiesta ST
Please don't link to sites selling counterfeit cables.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Genuine VCDS is best but its not cheap - around $400 bucks but works and regular updates and you get access to VCDS forum support as well
