Originally Posted by
Johnbu
While I don't disagree with you, slotted pads and better than Standard dot 4 will be wasted by 95% of drivers, including the OP.
To the OP, remsa pads are perfect for your needs, equal to OEM performance with much less dust.
The issues is you should machine your disc if you are changing pads types/brands. If you machine it may be undersized. Plus due to the cost of machining, you may as well replace it.
I paid ~$100 for the remsa's and $110 for RDA discs for the front axle (rear pads cheaper and discs more expensive).
Agreed, but the small cost difference between slotted and std, and the small cost difference between std and better fluid, along with better pads will make a difference those times (the 5%) he is driving spirited. Just aim for pads that have the same cold performance, but better hot performance. Most aftermarket will have that
2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
