I have confirmed that the settings I used have activated the front camera's recognition of speed limit signs in Melbourne. It works well in testing over the weekend, but I haven't tried at night.
Most of the time it gets confused by school zone 40 limit signs (including the yellow ones that I think are warning of an upcoming school zone?). Only once did it realise there was a time limit of the school zone - it then shows two symbols, a 60 and a 40 with a time icon underneath.
http://www.vwwatercooled.com.au/foru...g-img_2827-jpg
A second time past the same location just gave a standard 40 sign.
It even detected the 20 zone in the Bunnings car park :-)
I followed the steps in the first post here
How to enable Traffic Sign recognition - Skoda Octavia Mk III (2013 onward) - BRISKODA, except I didn't bother with the 'Select channel Display end of speed limit symbol' step because we don't have end of speed limit signs here (not seen one in my 10 years here, but I'm familiar with the UK ones).
If you do that, you still won't get any signs detected. You then need to change Controller A5, Adaptations, Road sign detection fusion mode to 'Road sign detection'. It will then work, but will only use road signs, not a combination of the satnav data and road signs which is how it works in other locations. It must be using GPS to limit where it will detect signs which is annoying.
My car has the 2016/2017 ROW satnav data, and the media system version info screen shows hw 050, sw 0315.
@mysticality, any chance of checking another MY16.5 Octavia RS to see what media system versions there are out there?
Ultimately unless I can find a way to combine with the satnav data I will probably turn it off. With only the sign detection the speed limit info doesn't update until you pass another sign, or the car is switched off.
