Read the last two pages if this thread It seems you have a Discover MEDIA and so need the 4GB map HE has the same trouble as you and wrong assumption of model of unit
Maps update
What unit is it you have as Rednuts looks like a Discover MEDIA NOT a PRO
Does it come with is own VW supplied SD Card and if so Its NOT a pro and uses a 4gb map and MUST use its own card.
Where did you get the firmware from as have never seen any updates sine the old RNS510
Maps update
naturally all my peripherals are either 64gb or higher and 16gb or lower. neither the sdcard or usb drive worked with multiple formats and data sources. i'll try source an old 32gb drive to test with. thanks for the help.
2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
1.6L 5 Speed Mk2 1990 Golf - goneski
You can use any size SD card Ive got the map on a 128gb micro card and it works
I think you are using the wrong map
Another forum - took a while to download as it was one of those free hosting where they always want you to upgrade to get faster speeds, but I have it. I cannot recall the forum (maybe Briskoda) but in reading everything, it showed that the most stable and latest version was 1433 - so that is what I downloaded and unzipped. It came as a pack - it was 1433, 1382, 1240 and 1440, but apparently 1440 can have issues on older units whereas 1433 appears to be fine with all ages. Given mine was 2016, I went for 1433 and it worked a treat.
Given I was on 0318, there was lots to do. One example is the old f/w version did not show speed limits in the maps, even with the latest maps. Once I updated it did.
2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
i managed to track down a 32gb microsd so i formated to default allocation with FAT32. extracted the latest ROW map data(p90) and i still get the same error message, currently trying again with p88 but assume i'll get the same error. Perhaps i have an incompatible firmware version at the moment? i found 1 instance of someone who is/was in Melbourne with the same device/hardware/software config as me who had the same issue but their last forum post(Briskoda) was in 2019 so im doubtful they'll respond.
it appears the issue may be because it's a MIB1 system. some folk over at Briskoda suspect said unit doesnt allow for unlimited updates like the newer models. I managed to get it into service mode and it's detecting the update but it just wont let me update it! I managed to get a response from the dude in Melbourne too and he said they'd stopped trying back in 2019 but is now keen to have another crack at it. i just hope tinkering in service mode doesnt lead to bricking it. i'll keep trying and report back.
just called the local Skoda centre and they 'dont think its supported anymore' and that 'it probably cant be updated'. i refuse to believe that..
