Lets not confuse engine codes, engine numbers, and part numbers here.
Replacement engines aren't stamped with an engine number from the factory. QLD Police will issue one to the dealership, which does not include the engine code at the start of it, like a factory-fitted one would.
It'll be a long motor, which your dealership will swap CCZ-specific external parts over off the old engine onto, or order new if they were damaged during the failure.
In essence, your engine code stays the same, the part number of the long motor will be correct as it is VIN-specific, and may have an X at the end of the part number on the invoice meaning that it is a factory exchange engine, but your engine number will be different on your rego papers. It will be whatever number the dealership is told to stamp on it to ID for legal purposes.
