Ok more traction is required for the Stage 2 tune to put it to better use...... Currently running stock suspension setup and things get a little crazy laying the power down.
Thinking about Eibach springs (20mm drop) and Superaloy lower control arms with anti lift kit or just the Eibachs and the Whiteline ALK this setup I'm hoping will give the car a better stance and keep the nose down on power application increasing traction. Want to keep the stock shocks as they are only 10k old.
Turn in and feedback through the steering wheel is quite doughy and does not give that connected feeling with the stock setup so I'm also hoping the above mods will improve this too.
Can anyone comment on this setup or something similar? Maybe Martin can chime in as your setup is similar, are you running the APR lower control arm kit with caster adjustment anti lift etc?
Thanks in advance for any feedback. :)
MGT
