Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: B1 engine recommendations
    Wouldn't a 2.0 8v from a MK3 Golf be OK? It was a straight swap into my MK2 and I kept my 1.8 head and put it onto the 2.0 block.
    Dec 2015
    South Africa
    I did a 1800 Short block from Jetta CLI. bored out to Fit 2.6 Caravelle Pistons ( Std 82.5mm ) ... Kept 1800 Crank and Rods..
    made good power with a worked Carb head and Weber Carbs on golf
    bolted straight on with no issues
    Interesting mod. What capacity do you end up with, 2.0?
    Dec 2015
    South Africa
    To get technical, Its gets you a 1897cc ( 1900 ) setup..
    With a 2.0l Crank, takes it to 1997cc ( 2.0l ) setup...
    got 127kw with 233nm torque out of it on my 4door SA 1800 sport golf ( later model golfs ).
    My 2 Door GTi had similar setup, only i had it up to 2091CC (2.1l) stroker with Tdi crank(Balanced and knife-edged) Stock rods and 82.5mm Pistons. head was skimmed 1.5mm ( on its last ) to get me a 12.6:1 Compression... ended up with 137kw and 312nm torque on that little 8v..
    Oct 2006
    Perth WA
    B1 with a 20v turbo installed
    B1 engine recommendations-img_2565-jpg
    2.0L 16v Audi 80 - Project
    3.0L 30v Audi A6 quattro - Daily
    PERTH
    That looks mint,
    Found this "how to" forum post, pretty much tells all
    VWVortex.com - ***VW Fox 16v swap FAQ***
    Just gotta get the donor car with the engine, might be hard in oz but it's a start,
    Though just thinking if the 9a 8v bolts up to the Passat gearbox I have fitted the KR 16v head to this block before, hmmm and I'm guessing those 20v - 16v Audi motor are non existent in oz.
    the golf is not dead.
    The 9a is a 16v engine so why would you put a KR head on it?
