Results 1 to 4 of 4
Thread: How do I remove my top strut nut? (KW v1 coilovers)
    May 2010
    Hi guys,
    I'm having trouble removing my top strut nut.
    Trying to get the coilover out and when I turn the 21mm nut, the strut keeps spinning with it.
    Is there a way that I can stop it from spinning?
    I've already removed the disc, hub and knuckle (bearing housing).
    I did try to remove the strut nut first but was spinning then, so didn't think it would matter if I get that stuff out and then the the strut nut last.
    Any suggestions?
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    you need a allan key to hold the strut, with a socket around it.
    so hold the strut in position, and turn the socket via a wrench.
    VW or someone do make a special tool to make this a little easier but the same principle applies from memory
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2010
    Thank you Dylan and RayRay.
    You guys are so helpful, most sppreciated.
    Strut is now out!!!
    anytime
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
