Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: WA - mk4 4motion guru?
    Apr 2020
    Perth WA
    Hi all - I’ve recently bought a mk4 bora 4motion and am going to need some help with diagnostics on what seems to be the usual haldex issues.
    Is there a guru or workshop in Perth that is particularly knowledgeable / helpful that I can contact?
    I’m currently running the car in “2motion” with fuse 31 pulled to turn off the haldex. With it in, the car behaves as if it’s got a solid rear axle - a nightmare in car parks.
    I’ve serviced the haldex & rear diff. I’ve lifted the handbrake a few clicks and it doesn’t disengage. I’ve seen the list of things that need to be checked - I can’t do it all so want to know where to go so this won’t cost an arm and a leg training up a local shop.
    Apr 2014
    Penrith, NSW
    My first thought would have been to service the Haldex. Do you get any traction control or ABS lights up on the dash?
    Apr 2020
    Perth WA
    I had no warning lights and no relevant fault codes. Now that I’ve pulled the fuse the traction control light is showing on the dash.
    Apr 2014
    Penrith, NSW
    Does it only happen at low speed? and more so when turning at low speeds?
    You'll definitely need to get it scanned using VCDS (Vag-Com) or similar, but it doesn't always throw a code.
    Mar 2020
    PERTH
    I’m similarly in the process of working towards a DIY Haldex service here in WA.
    I have seen that a key recommendation from the YouTube experts is to remove the motor and clean the filter screen on it. This is a worse place for clogging than the actual filter.
    This is not done in a standard VW service which is purely changing the oil and not even the filter which exists on earlier models. VW don’t even have a part code for the filter.
    Apr 2020
    Perth WA
    Hi - which motor needs to be removed? Do you mean the precharge pump?
    Anyway I’ve run fault codes again - I’m getting 00526 - brake light switch (F) 27-10 implausible signal - intermittent. (Going back I see this was there when I bought the car and it didn’t seem to be binding then).
    I also checked the measuring blocks and saw it is detecting both hand brake and foot brake switches. The pump is running 100% of the time when the engine is running but off when the engine is not running (ignition on).
    Clearly this should not be so, but there don’t seem to be any other blocks on the Haldex that are meaningfully measurable.
    Should I be checking something else? I know the ECU and ABS control units send signals, but should I be looking here and if so what for?
    Or if the pump is always running does that mean the haldex controller is bust? No other options?
    Apr 2020
    Perth WA
    Oh yeah I only detect an issue at low speed and more so when turning at low speed. I haven’t driven far with the pc plugged in but I would assume the haldex is engaged even at high speed if it’s on at low speed (and shouldn’t be)
    Mar 2020
    PERTH
    Quote Originally Posted by Overtaker View Post
    Yes the Haldex has a pump motor hanging out of it.
    Apr 2014
    Penrith, NSW
    Quote Originally Posted by Perthdisco View Post
    I have never heard of this on Gen1 Haldex units but it makes perfect sense. Great tip.
    Mar 2020
    PERTH
    Quote Originally Posted by beale187 View Post
    I am no expert for sure only understand that the 2010 Tiguan that I have has the Gen 4 Haldex. This has a removable filter and pump motor.
    Not sure the difference on earlier versions. Later versions don’t have the removable filter it seems.
