http://www.vwwatercooled.org.au/foru...tml#post846579
Printable View
Car: VW Bora 2lt FWD
Wheels: Audi A8 Flat5s
Front: 18x8.5 et30 (after 15mm adapter) 215/40/18
Rear: 18x8.5 et25 (after 20mm adapter) 215/40/18
Fenders Rolled: Yes
Fenders Pulled: No
Camber: Rear has additional 1deg each side (approx 2.5deg each side total)
Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear.
Notes: Perfect daily spec... proper sized and legal fitment, wheels would have sat inside the guards if my rear beam was centred (is now), looked like factory wheels.
Would have loved to go lower but rubbing the drivers side driveshaft on the body and wouldnt have lowered the rear anymore without the front going down because cars should have rake :P
http://www.vwwatercooled.com.au/foru...4a08a1_o-1.jpg
http://www.vwwatercooled.com.au/foru...d9996e_o-1.jpg
http://www.vwwatercooled.com.au/foru...3b6cc8_o-1.jpg
http://www.vwwatercooled.com.au/foru...95415d_o-1.jpg
http://www.vwwatercooled.com.au/forums/
Wheels: Genuine BBS LMs
Front: 19x8.5 et30 (after 25mm adapter) 215/35/19
Rear: 19x10 et32 (after 20mm adapter) 235/35/19
Fenders Rolled: No
Fenders Pulled: No
Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear and wound up 10mm.
Notes: Had these on at too stages, most of the photos are from GAF11 are with the arches unrolled and rear wound up 10mm
then back it up for Nats12 with the fronts rolled and rears wound down. made for fun times with 4 people in the car..
again, would have loved more lows but the front driveshaft was in the way.
the later photos:
Wheels: Custom Teledials
Front: 18x8.5 et30 (after 20mm adapter) 215/40/18
Rear: 18x9 et30 (after 15mm adapter) 225/40/18
Fenders Rolled: No
Fenders Pulled: No
Notes: Had these on at too stages again, early stages car was a bit higher and didnt have extra camber (Nationals 2011)
then the car was lowered all round and the shims were left in after the LMs. Arches were also rolled in recent times.
Will be improving the specs shortly
for reference, this is what a 215/40/18 looks like on a 8.5 and a 225/40/18 on a 9.
these fitments meet the manufactures spec believe it or not.
Wheels: Axis Pentas
Front: 19x8.5 et35 225/35/19
Rear: 19x8.5 et35 225/35/19
Fenders Rolled: No
Fenders Pulled: No
Camber: None
Notes: fitted this not long after clearing a defect so car started high again then came down.
Front poked so much in the first photo.
http://www.vwwatercooled.com.au/foru...IMGP8438-1.jpg
http://www.vwwatercooled.com.au/foru...IMGP8439-1.jpg
http://www.vwwatercooled.com.au/foru...IMGP8440-1.jpg
http://www.vwwatercooled.com.au/foru...IMGP8457-1.jpg
Wheels: BBS RS
Front: 17x7 et20 (after 20mm adapter and 5mm spacer) 195/45/17
Rear: 17x9 et20 (after 15mm adapter) 205/45/17
Fenders Rolled: No
Fenders Pulled: No
Camber: None
Notes: My first real crack at fitment. not great, but have to start somewhere.
195/45 is WAY to small in profile for the height of the car or even a slammed mk4.
