Results 1 to 7 of 7
Thread: Under Drive Pulley set from ecs
    Jan 2010
    Greenvale, Vic
    hey guys has anyone purchased lighter pulleys for their golf already? im gona experiment a bit, and whip out the cash to get some
    http://www.ecstuning.com/Volkswagen-...ulleys/ES3568/
    the lighter parts and smaller diameter should beef up the power curve a bit should it not? if anything it'll look great, has anyone done a similar upgrade before? and got results or feed back to pass on?
    Ante
    Jun 2008
    Cronulla, NSW
    i'll see if I can find it (not sure if it was posted here or elsewhere) but reducing the weight of the drive puleys really upsets the harmonic balancer and can severely damage the engine. i'll see what i can find.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Jan 2010
    Greenvale, Vic
    wow sounds kinda scary, thanks for the help
    Jun 2008
    Cronulla, NSW
    here is an interesting back and forth
    http://forums.nonewbs.com/showthread.php?t=219190
    Bottom line is you WILL be reducing weight on one end of the crank and over time (how much time nobody knows) it will increase the vibration thereby increasing load and therefore wear on your bearings. for such a minimal gain, i'd not bother. but thats just me.
    Jan 2010
    Greenvale, Vic
    yeah i see your point and their too. So many conflicting views on the matter, i guess best to play it safe
    Quote Originally Posted by AnteGTI View Post
    Spend your money on a flash, downpipe, intake, lightened flywheel and clutch, lighter wheels, suspension and brakes before pulleys. Not necessarily in that order.
    Dec 2007
    Brisbane, Southside...
    Yeah I always look at the lightened pulleys (not underdrive) on ECS when I buy something else and in the end the ambiguity about the effects they have always makes me not bother with them. At the end of the power isn't everything and especially in your case there are lots of other things you can spend your money on to get better results.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
