If you lift the boot over the gear knob you can see a collar that holds the knob on the shaftI think this collar needs to be sacrificed to get the knob off
Hi all
I would like to replace the gear knob on my Bora V5. I have tried twisting it off anti-clockwise but the whole boot moves with the actual gear knob. Is there a trick to it that can be explained to me?
Cheers Matt
Thanks Sukebe
How do I get the gear boot over the gear knob?
Matt
The plastic trim has clips in the dash, unclip them and lift the gaiter over the knob (it will still be attached but you will be able to access the collar
Thanks Sukebe
I'll have a crack at it on the weekend.
Yep, you are supposed to replace a clip but I did read a post where someone worked it off slowly to preserve it.
