Hey Guys,
My MK4 R32 has a small rattle between 1st 2nd and 3rd when i take off at low rev's, i read somewhere that its got something to do with the heat shield on my exhaust.
I still haven't found a clear solution to my problem.
I don't usually take off at low rev's but sometimes i just like cruising my car.
Can someone help?
2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
I think he was looking for more of a suggestion of where to start looking and if anyone else has had the problem, rattles are a bugger to find.
As said, try having a play under the car to see if you can't locate the culprit. Try and imagine the resonance level of the engine and see if you cant reproduce it somehow.
Dude, don't be so harsh on the poor guy. He may not have the infinite wisdom that you so obviously carry!
Maybe this is a common issue and there is a simple solution.. Not everyone is very mechanically minded and some people struggle with this kind of stuff.
I hope someone else with an R32 can offer some useful advice rather than turning a new forum member away.
Hi mate and welcome to the forums. Head over to the newbies corner and introduce yourself and post up some information and photos of your sweet sweet ride.
In regards to your problem, I'd give graeme86 a PM about your issues as he seems to know everything about the R32 and should hopefully be able to help you out. And yeah get under there and have a good poke around.
Cheers,
Trent![]()
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Thanks for your advice.
Yeah i had a look, but im no mechanic, i found myself just looking and poking, but thats all. Couldnt see anything abnormal.
I will head to the newbie corner.
Yeh just picked it up a month ago..
awesome car, cannot drive anything else anymore! haha
At what speed and gear were you in when this rattle occurred?
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
1st,2nd, 3rd @ low rpmAs per title, but actual rpm would help... 1,500 RPM'S ? 3000 ?
Below 3000 rpms. The sound is between a rattle and knock, its not that loud.
When the car gets goin it doesnt do it anymore.
check gbox and engine mounts ...put a bar and try to move them... Check exhaust pipes all the way back for clearance one of the rubber "hooks" might be off?
