Results 1 to 10 of 10
Thread: rattle under acceleration at certain rpm
    I'm not sure how long is been there due to noisy tyres. But I've just noticed a new metal on metal rattle.
    At first I thought it was the catalytic converter again, but seems to be coming from the engine bay.
    Happens when say I accelerate in 2nd at low speeds. Can hear it at 3krpm, then at around 4k rpm. Fairly consistently.
    Can hear it in other gears too, just Havnt narrowed down at what rpm and when etc.
    Pretty quiet, enough that I can't seem to hear it in 5th at speed.
    Any ideas?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Get in 3rd under similar rpm too I'm pretty sure
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2011
    How's the oil level???
    Could be a heat shield or some other metallic object rattling.
    Quote Originally Posted by grtuned View Post
    Low (standard 8v burning it all), but within range
    Hmm thought that, but haven't touched the car for a while. Wonder if the dog bone mount is just now so dead it is hitting on something as you say
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2011
    Top it up and holds the revs at 3000rpm for a couple of minutes and then check. If it dulls down might be a lifter issue.
    Oct 2011
    Gold Coast
    oxygen sensor? Mine rattles at a certain RPM, need a tool to tighten it back up but I think this is what you are hearing
    Only had a top up a few days before I first noticed it, I'll see if it's gone down enough to get much more in
    Quote Originally Posted by koji View Post
    Hmmm, I'll have a look. That one has been in there for a 2 years or so now so shouldn't have wiggled free though fingers crossed.
    Probably due for a chassis inspection anyway, it's been a while since I've had it in the air
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2010
    NQ
    I've had engine vibrations transfer through my shifter linkages and 'through' my gear knob, sounding like a metallic rattle/ring.
    This in on a 02Y gearbox though, so don't know if it would happen with cable shift box's.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    I had similar on the Vento actually, fixed it by moving the heat shields around a bit (I think so anyway, Havnt driven it far or at speeds since)
    Bora has fixed itself I think? Maybe something was stuck up under the car causing something else to rub?
    Thanks for the suggestions guys
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
