Results 1 to 10 of 15
Thread: My R is a swimming Pool!
    Dec 2008
    I have a problem. My R is leaking badly on the rear passenger side footwell. I have vacummed probably half a litre out of it today. Its not the window...its been air tested as I noticed this again after heavy rains a few months ago. After spending about an hour in the car today...there is no sign of the car of water coming in. All the headlining is completely dry. All the pillars completely drive. Drivers side completely dry. Had a bit of a search on Vortex, seems to be a fairly common problem with R's and Mk 4s with sunroofs- drainage nipples clogged. (exactly same symptoms as me- a pool of water in the foot well)
    http://forums.vwvortex.com/zerothread?id=4634915
    http://forums.fourtitude.com/zerothr...ostid=62103515
    Do non-sunroof cars have similar nipples? Where are they? Need help please!
    Dec 2008
    hmmmm.............Also just found this...
    http://forums.motivemag.com/zerothread?id=4119913
    Could be so many of these. So has this happened to anyone else?
    Are these the ones under the doors...?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Nov 2007
    Coffs Harbour
    Nope ask vwtech he just solve the problem before he bought my R which i notce leakin during the big rains we had in Coffs......Pollen Filter. area pm him.
    Dec 2008
    Quote Originally Posted by JVLR32 View Post
    hmmm...will pm thanks for that. Checking pollen filter area now. Seems to be a little damp, so it could be the nipple thing next to the pollen filter housing.
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by pauld View Post
    YEP....thats where it is then
    Dec 2008
    Okay...so I poured a small amount of water down where the nipple is (next to the pollen filter housing) ....most of the water drained out from below...but lo and behold...water soaked to the rear passenger footwell.
    So I have found the source I think.
    Nov 2007
    Coffs Harbour
    good
    Guest0608 Guest
    remove the wipers and scuttle panel from lower screen and remove the pollen filter, the housing that the pollen filter sits in has to be water tight so it doesnt get into the fan and cabin, remove the two 10mm bolts from either side of the housing and you will find it has a foam gasket, pull this off completely and clean the surface, make a nice bead around the surface where the old foam gasket was with "sticker flex" windscreen sealant or your left over shower sealant! stright away fit the thing back on with the 10mm nuts (of course clean the body first!) let dry and then retest, also there is a small rubber grommet between the pollen filter and wing that is used for the bonnet cable on L/H drive version, sometimes comes through there. The A pillar drains are only for sunroof models mate, its where the sunroof drains off, and yes they do get blocked and need a press and also a blow out from the top with a air line. Water will get into the back as much as the front even if only on a slight incline. Hope this helps, ..........VW..........
    Dec 2008
    Quote Originally Posted by vwtech View Post
    Thanks heaps for this Pete. I have contacted the dealer (not VW) where I purchased the car from. Hopefully it will be fixed under warranty. If not I will be doing it by myself. Was yours leaking as bad as mine? Is this a common problem on the R's that a VW dealer would know about?
