Rear brake solid to vented qns
Can i go straight from solid rotors to vented? (staying at the same diameter)
The vented rotors will be around 22mm thick, while the standard rotors are 9mm. Will this mess with the calipers and or pads grasp on the discs??
Here is a rough diagram of how i imagine it:
red bit is the caliper, blue bit is the pad, and black part is the disc.
http://i6.photobucket.com/albums/y23...titled-1-1.jpg
TIA,
Phil
- You may not post replies
- You may not edit your posts
Forum Rules
